i was driving and I smelt eggs. I pulled over to see my battery smoking.
SO I had to make it home. I kept driving and i started seeing sparks and smoke from gauge cluster and under dash fuse box.
I towed it home and replaced like 10 blown fuse.
I also had to change 3 under food fuse. Well i bought and new battery, and now notthing cut ons. only oil light. notthing on dash and no start or crank.
my windows is down and i can't close em. I ran the 12v and ground manualy to the door harness and the driver window is acting wierd. It won't go up but i can put up the passenger window.
I think i got a major short. I put a test light on the bat negative and connect positive to bat and light stays on. i pulled all the fuses, and light dosen't go off.
what else can i check? PLZ HELP!!
