blew it up! Why?
Discussion in 'HYBRID -> EG-EK / DC' started by honda801, Jun 19, 2007.
  1. honda801
    honda801 New Member
    SLC
    i have got a 00 ex coupe, just swapped the d16y8 out with a 98 b18c1. while i was waiting on tires i started it up let it idle, rev it up a few times, everything sounded ok. when i got tires i fired it up hit the road, the car started bogging and not more than 100 ft blam oil hit the winshield. YES I CRIED:(. i turned it off and pushed it back in the drive way. found two golf tee sized holes in the webs of the block below the left piston(closest to the tranny). what the hell did i do wrong. keep in mind this is my first import swap but im not new to motors. if the iac or cps or was wired wrong would that cause this? im not 100% i wired those correct. but it seemed like it was ok before i started out.
    anybody?
  2. honda801
    honda801 New Member
    SLC
    you must know something what could cause the bogging only when driving and why did it go boom!
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    naa, swapping those two would make it run like ass, not throw a rod.
    Could have had a spun bearing.. Was this motor freshly built or used? Where did it come from?
    Crazy question.. you did remember to put oil in it, right?
  4. honda801
    honda801 New Member
    SLC
    it was freshly built and yes i doubled no triple checked the oil.. i left three quarts righ in the middle of the road.
  5. honda801
    honda801 New Member
    SLC
    so maybe spun bearing and wire problems?
  6. SHOGUNOVDDRK
    SHOGUNOVDDRK New Member
    australia
    more then likely.....and yes i would have cried too :mellow:
  7. welfare
    welfare Ancient Member
    New York
    You may have popped the head gasket, sucked in the coolant and then tried to compress it (not healthy) When you pull the motor apart check the head gasket on the offending cylinder, other than that who knows.
