Block Guard Question
Discussion in 'Engine Building' started by R.E.Developement, Oct 19, 2003.
  1. R.E.Developement
    R.E.Developement Import King of Irvington
    i am looking to do a lsvtec turbo setup nothing big,just something to play around with and to get to point a to b in my 91 integra. the is what i have in mind right now
    b18a block (i already have)
    b16a head (i already have)
    sir trans (i already have)
    gsr oil pump
    gsr water pump
    gsr timing belt
    new bearings
    arp rod studs
    arp head bolts
    comptech turbo head gasket
    aem fuel rail
    aem fuel pressure regulator
    440 injectors
    vafc controller
    dual stage boost controller
    thats what i have in mind to do but ive heard that i can use a block guard also.
    where would i get one from and how much will it cost
  2. 11sec. ALLMOTOR
    11sec. ALLMOTOR Junior Member
    we carry Block guards made by JG or str $125 shipped in stock :spin:
    Also have the RC 440cc $275 shipped in stock and we are a distri. for DRAG turbo kits
  3. brian11to1
    brian11to1 Senior Member
    i think you'll need to use the LS timing belt... that's what I was told to use, and that's what im using... Im doing LSVTEC also... I got the B16A1 head, gsr water pump and LS TB... got the B16 IM, and a Hedman Chikara Header... that's about it still looking for a crank rods adn pistons... and rings... damn though
  4. Tonyd0821
    Tonyd0821 Banned
    can i quote an internet rumor? (this way by saying it is a rumor, you fuckers cant flame me....)
    but from my "d" series turbo board, i was under the impression that a block guard on a street car would do more damage than good. few peeps were saying it blocks the coolant flow etc.
    anyone dispel this myth or?
  5. CRX_B16B
    CRX_B16B Senior Member
    insted of a block gaurd go for the Darton MID sleeves they seem like they would work good. :)
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Timing belt and water pump need to be from the same engine. If you use GSR water pump you use GSR timing belt and vice versa.
  7. kevs_92gsr
    kevs_92gsr Junior Member
    If you want a block guard you can get them for $100 on optionsauto.com!!! ;)
  8. deth101
    deth101 Senior Member
    usa
    there is a reason block guards are $100......do it right and get a sleeve with a deck.golden eagle,or aebs would be good places to start looking
  9. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    block guards are not even worth the 100$ unless your running like a NOS d series or some other ridiculously weak explosive motor
  10. pissedoffsol
    do a search under my name in the FI forum for block gaurds. I've covered my opinions on this several times.
