Blox B
Discussion in 'Engine Building' started by b18cef, Dec 28, 2007.
  1. b18cef
    b18cef New Member
    does anyoneknow weather blox b cams wil be ok with type r valve springs? or what about Blox A cams? thanks
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Do some searching to compare the lift/duration between the two cams. If there is a significant increase in the blox B's(which there should be), get new valvetrain. s2s1's are ok for itr valve springs. Blox A's should be ok, slightly above the itr. IF you run the Blox A's, just dont rev past the ITR's redline and you should be fine for the time being.
