Boost!
skellagher
Elder Driver
i have an itching to get my boost on so should i just boost my b16 or buy an ls and boost that?
depends on what your budget is and what you really want...but something to consider is that you could do an ls/vtec then boost it cause you already have a vtec and ls blocks are pretty cheap
the problem with ls vtec is that they are not too reliable... i mean if its sooo great y didnt honda just build that motor to begin with you know... budget is not an issue although with that said i do not wish to build a motor just a stock motor some bolt ons and like 10psi...
well in that case since your running low boost and not on a budget just boost the motor you have now because it would definitely be a good boosted motor and if you wanted to just throw some parts at it and crank up the boost
