you both have got to be fucking shitting me?
learn your driving habits? bwuahahaha stay the fuck away from building motors... if you want an educated response on engine break in, read this...
http://importbuilders.com/breakinarticle.htm
well someone here is a fuckin ediot....we wont say any names (B16RacerN2NR)...before u start posting sites to try to disprove someones knoweldge...you might wanna take the time to read what the fuck ur posting...
the site you posted about breaking engines in has to do with NEW engnies either rebuilt or fresh from the factory. theres not one article about breaking in or running USED motors on that site at all. and last time i checked u dumb shit, nobody said they were building or rebuilding an engine. the kid who posted this topic CLEARLY said he has a USED JDM motor and im pretty sure he didnt rebuild it or change anything internal.
since you can read..let me cut and past SOME of the topics that YOUR refered site talks about:
1)I got a <span style="font-size:12pt;line-height:100%">brand new block/engine </span>and I want to break it in properly. What should I do first?
2)I got a <span style="font-size:12pt;line-height:100%">brand new block</span>, fully built and its burning a lot of oil, WHY?
3)You got advice from your engine builder, but don't take it and listen to your buddy who thinks he knows better, or your local shop.
......this whole site has to do with REBUILT engines. not USED JDM engines. so before u start discrediting others advice and making yourself look like an ediot. id suggest you read before u post.
oh and by the way....you ecu does read your driving habbits...which is why there are sensors that report back information to your ECU. if that was the case then there would be no need for O2 sensors or map sensors or temp sensors or especially knock sensors that throw your whole damn car into a open loop mode when activated. last time i check, these sensors are Reactive sensors and respond to actions that you engine produces and they DO not reset themselves, therefore if a sensor in a car is sending back information the the ecu dosent recognize...the ECU will try to react to that by compensating something like fuel, timing, air, etc. many people especially factory boosted cars have this problems like SRT4's and WRX's, ask anyone who has one of those vehicles and adds mods to try to increase the amout of boost with a stock ECU. in the beginning, when u reset the ECU the car will let you run the boost YOU have it set at but eventually the ECU will counter-react that boost PSi and will think there is an OVERBOOST situation and will reduce it back to its regualy boost PSI.
