Are the BSQ brakets/mounting crap need for the ITR bar if I am running ITR LCA's. I heard from somepeople that you do and from others that you don't. Can someone help me with this. I want to order everything within the week. This is all that I need right? 52300-ST7-Z01 rear swaybar 52315-ST7-Z01 swaybar bushing (2 needed) 52308-SS0-000 bushing bracket (2 needed) 52316-ST7-Z00 endlink bushing (2 needed) 52312-ST7-Z00 endlink bushing collar (4 needed) – reusable from the stock sway bar 90175-ST7-Z00 bolt (8x35) (2 needed) 94050-08080 flange nut (8mm) (2 needed)
i'm using the beaks kit on my car now, works great and no problems so far... and i do some pretty aggressive road racing on that car
The kits are for the subframe, I don't think it matters what LCA you are using, the subframe is still not the same strenth as an ITR, so I would say yes they are still needed. You can get the D brackets with poly bushings for less than the OEM pieces. They have them at parts stores even.
