Build B20B
Discussion in 'Engine Building' started by a_yousry83, Jul 3, 2005.
  1. a_yousry83
    a_yousry83 Junior Member
    I want anyone to help me,i build B20B Block and GSR head,i want to know how much the hp,i want to know this engine is good or no.thx
  2. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Go to the dyno and find out. The motor is only as good as who built it, so who knows
  3. a_yousry83
    i am from egypt and didn't have dyno in egypt.
  4. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I've read about B20/vtec's making 220-230 hp to the wheels NA. (Naturally Aspirated). I'm sure if you ask anyone, they'll tell you to go for it.
  5. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    I am sure that doing requires much building of the engine internals. Once this is completed, this combo is easily the most potent "engine swap" due to the torque and hp numbers.
    I think you will need.
    better than b20
    connect rods
    and pistons and such
