Build Pics
Discussion in 'Engine Building' started by lsvtec, Mar 14, 2003.
  1. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    On the engine stand after getting the bottom end together.
    A closer veiw and a good shot of the clean bore.
    A top veiw, these pistons are beautiful.
    Getting ready to clay the engine.
    The head on the block, not rockers or cams. Mmmm Skunk2 Valve Train.
    After turning the engine over. All kinds of clearance. I didn't have access to a compressor so I checked clearances on the small cam, then measured the largest difference in lift between high and low. Then I made sure I had a little more clearance than that difference.
    On the engine stand, but almost ready to go into the car.
    Intake side of the engine
    Distributor side
    It's ready to go in the car.
    Finally the exhaust side on the hoist.
    The car is running well. I need to adjust the TPS a little more. I will do that tomorrow when I have a little light to work by. It seems the speedo cable came off the gauge pod during the reassembly so that needs to be reconnected, but the car is running great.
  2. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    sick, im jealous as hell
  3. lsvtec
    Start saving your pennies and you too can blow your savings on your car. :) After driving it some tonight, I think it has been well worth the cost and the effort.
    I think I forgot one.
    The Koni Yellows with H&R race springs that went on.
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    simply beautiful man! good job :thumbsup:
    those roller wave pistons? if so, what CR you runnin in there?
  5. lsvtec
    Thanks. :)
    They are roller waves. They are setup for 11.5:1 LS bottom end at 81.5mm with a B16 head.
  6. B16
    yay area, CA
    nice, that bitch will haul :)
    throw her on a dyno when its all broken in, i'd like to see her numbers :)
  7. lsvtec
    I am saving for a Hondata next. As soon as that happens I will dyno it. Hopefully by the end of this year as there are no dynos anywhere close to me.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Very nice. That's the best that Wally world could do on scanning pictures in? They look kinda grainy. :(
    You should make damn good power on that setup! I watched a guy make 190/130 to the wheels today. This was his build:
    B18C1
    Skunk2 valvetrain
    Skunk2 Stage 1 cams
    Skunk2 intake manifold
    AEM cam gears
    AEM CAI
    Comptech 4-2-1 header
    Greddy Power Extreme exhaust
    Hondata
    All stock bottom end!!!
    I'll post a scan of his dyno sheet as soon as I buy a scanner (hopefully tomorrow). He's 57one on H-T... I talked to him about his setup while we were there.
    Eric- hopefully you can make a lot more power than him, since you've got that extra bit of stroke and higher compression.
  9. paragus
    paragus Senior Member
    sick.. its just plain out fuckin sick. maybe one day ill get mine done aahhhhhh :lol:
  10. D See 2
    D See 2 Senior Member
    Baltimore, MD
    what happens if your tps isn't adjusted correctly? what should the voltage read at closed throttle? what should it read at WOT?
  11. lsvtec
    Yeah, the picture quality was pretty sad. That was the best they said they could do. And on top of that they made me buy a set of prints to get the CD. I need to find another place to develop pics.
    As for the TPS, if you read the voltage on the Red/Blue (should be in the center) wire by attaching one lead of a volt meter to it and the other to a ground (chassis works) it should read .5 volts closed and 4.5 WOT. All that from : http://www.hondaswap.com/forums/index.php?...t=0&#entry78589 .
  12. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Beautiful man. :beer: I'm not going to be any match for you on the road anymore.
  13. lsvtec
    I would be quite pleased with those numbers. The only differences between his setup and mine are the built bottom end, the extra stroke, and cams. I am running ITR. Then he has a Hondata. I imagine I could work out those numbers if I could afford a Hondata. Saving for that could take a while as I am in school because I want the full setup. Then I have to go find a dyno, there isn't one in the area.
    Power aside, I am most excited about the car running so much better than it did. I haven't revved it out yet (obviously) so I can't say the blowby is gone (but I suspect so). The key differences are: no idle bounce (it used to bounce between 750 and 2500) and I am not throwing extra fuel out the exhaust.
    I want to thank everyone on Hondaswap for answers to various questions throughout this process, you all have been very helpful. :)
  14. phunky.buddha
    Nice. I'm sure you could make numbers close to that with a VAFC, given some good time on the dyno and some luck. :)
    I'm going to guess your power output at something like... 175-180whp. :lol:
  15. pjecthatch
    pjecthatch Junior Member
    dude sweet pics. how long did it take you to do the build?
  16. Havok
    Havok Senior Member
    Florida
    That's it : a C/C1 is going into the sol! He would to better if he had more agressive cams, tho.
    Add some Endyn roller waves and Eagle rods :worthy:
  17. KrUsHa
    KrUsHa Senior Member
    davie florida
    nice work man !
  18. phunky.buddha
    Very true. VTEC was still loud as hell when it kicked in though! I'll scan the dyno chart when I can get around to it.
  19. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    did you get the memo about the TPS reports?
  20. lsvtec
    To build the engine, it took me about a day and a half to clay it, plastigauge it, and completely assemble it. I took my time and did everything by Helms manual.
    1000 miles seems like forever from now, I can't wait to be able to open her up.
