b16stalyun
hey, i have a built b16 turbo. ive had several issues with my setup. It has been professionally tuned(not by me).
issue 1- i am going through spark plugs reaaaally fast. I currently have an msd SCI box w/ blaster coil, cap, wires. I was told that my ignition was so hot that im actually burning the gap open in my spark plugs. I installed a new set of plugs 1 week ago at a gap of .022. after 1 week my gap was at .024. the last set of plugs i went through burned from .022 to .028 in 1 month. Im also showing signs of detonation on all pistons. piston 4 is the worst. i was told that the SCI box was most likely the cause of the issues.
issue 2- detonation. would the SCI box be causing my detonation?
thank you
thank you
