built b16a
Discussion in 'Engine Building' started by DAallday, Feb 27, 2009.
  1. DAallday
    DAallday New Member
    I'm picking up a crx with a jdm b16a in it. i was told the heads built. also the guy said it put down 283 hp..i was wondering if this is possible with a shaved port and polished head, 5 angle valve job, skunk 2 retainers and springs, stage 2 turbo cams, skunk 2 manifold, b16a3 rods and pistons and crank..also he said it's safe to rev to 11grand...thanks
  2. efhondakid
    Akron-Canton, Ohio
    No way safe to rev to 11k, B16A3 internals are the same as any B16A internals, turbo cams on an N/A motor, and no way its making 283at the wheels.
  3. DAallday
    DAallday New Member
    i thought it sounded fishy. what power do you think its making then?
  4. efhondakid
    Akron-Canton, Ohio
    180 to the wheels maybe as a quick guess.
  5. DAallday
    DAallday New Member
    how much stock would it put to the wheels about?
  6. efhondakid
    Akron-Canton, Ohio
  7. DAallday
    DAallday New Member
  8. je power
    je power New Member
    my house
    if hes not fuckin around with you he might beable to rev to 11k but thats not to safe to do but its fun as hell. what compression is he running
  9. get_nick
    Washington State
    where are you at in washington? did you find the car on nwstreetracing.com?
    post the link to the car.
  10. DAallday
    DAallday New Member
    theres no link. tacoma area....
  11. get_nick
    Washington State
    do you have a shop/dealer name or is it just a private seller?
  12. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    I call B/S, find out what octane he's running too. Also, if it's turbo then I can see those numbers, but not that 11k rev
  13. DAallday
    DAallday New Member
    i believe he's running it on regular street gas. and its a private sale
  14. get_nick
    Washington State
    ask him where it got tuned. i know all the shops between seattle and tacoma pretty well.
    nobody is going to make 283 hp all motor. not around here. not street legal.
  15. DAallday
    DAallday New Member
    he said his friend built it and another friend had it tuned and dynoed.
  16. get_nick
    Washington State
    meh, if he can't name where it was, i would stay away. plus, a b16 just doesn't make that much power.
  17. Makahana187
    Makahana187 New Member
    dude, 11k on stock internals? if hes doin that the engine isnt gonna be long lasting...not to mention the hp rating seems a bit high for that
  18. Z6CRX
    Pittsburgh, PA
