built head
Discussion in 'Integra' started by makemagick, Oct 23, 2012.
  1. makemagick
    makemagick Member
    I was just wondering how much power can a built head give you with the stock block? skunk 2 pro 1s, aem adjustable cam gears, skunk2 valves, springs, retainers and port and polish.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Fifty bajillion horsepower
  3. dc4dude
    dc4dude Member
    chicago, il
    You sir, are off by a few bajilion... Give or take... Depending on what direction the flux capacitor is facing... True story...
  4. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    basically what they are saying is there is no real way to tell how much power u would make.. depends on the tuning\ tuner. could gain 50hp to 2million.. no real way to tell. real power will come from if u build the block to tho. more relaiable to.
  5. Briansol
    moving to a larger cam without adjusting the compression ratio by using a larger dome piston is like body building, and never doing legs. insert that pic here.
  6. makemagick
    makemagick Member
    Thanks, and yeah I will build the block eventually, i know it is kinda dumb to build part by part, but i dont have enough finances to do it all at once, so since the head is easier to take out I chose to do it 1st, but thanks anyways
  7. lostsoulzprophet
    georgia
    u could always buy parts and just store until you have everything. how i always did it.
  8. E_SolSi
    :werd:
    build it once
    build it right
