burning oil
Discussion in 'General Tech and Maintenance' started by FFCiv, Feb 7, 2005.
  1. FFCiv
    FFCiv Senior Member
    95 Civic with a b16a. Its burning oil. i did a compression test with mahciv today and got 190 185 175 180. I believe perfect is 184; not sure. When driving at low RPMS theres no smoke, but up at and near VTEC I can see almost a cloud of smoke behind me. There is a check engine light that comes on but I don't know how to tell waht it is; dont know if its related. Im guessing its either the valve seals, piston rings, or headgasket. No clue which it is
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    hmmm, from what i understand burning oil is a common deal with the vtec motors at high revs...
    you can do a leakdown test to try and determine if its the rings, or you can pull your valve cover and take a look at your valve seals...
    perfect is 184??? you have a cylinder at 190, and another at 185, and your motor has tens of thousands of miles on it... how can 184 be perfect?
  3. FFCiv
    FFCiv Senior Member
    the number my buddy got from a book was 184.... but that was for the usdm motor. Mine is just a b16a
  4. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    from what i thought 220 on the compression ratio is what is perfect!
  5. jamesA
    Standard on the b16a2 is 184, but you have a JDM motor so it'll be more than that. Probably between 210-220 since you're getting 190s and below.
    Sounds like to me you need new rings and a new head gasket.
  6. whiteLS
    whiteLS Senior Member
    Sarasota, Fl
    reading fromm the 88-91 crx B16 manual 185 is nominal 135 is minimum w/ a maximum variation of 28psi
    are you sure the smoke isint b/c youre at full throttle and your engine is running rich
  7. HCCAfan
    HCCAfan Junior Member
    x2, same thing mine is doing. running too rich. dirty injectors, bad timing, tune-up needed is your main causes of this.
  8. HONDA_F1
    HONDA_F1 Member
    NJ
    i notice that my b16 has a leak near the head gasket below my vtec solenoid and distributor
    i duuno ifi ts from the distributor or solenoid but its sitting below them
    also i've noticed that i have more oil consumption when i do alot of highway miles
    i have a s1 tranny so its reving between 4-5k on the highway
    but my exahust is perfecly clean from what i've noticed and i still lose oil
    (my bro was driving in front of me pushing the car and i saw nothing)
