Can I turn my D16 Non-Vtec to D16 Vtec?, and what do i need?
Discussion in 'HYBRID -> EG-EK / DC' started by DJTOON, Jun 6, 2009.
  1. DJTOON
    DJTOON New Member
    EVerywhere
    Just Bought a 2000 Civic Hatch with a D16 Non-Vtec...would love to turn into D16 Vtec...what do i need to do such thing and where and which motor do i get it from and get decent power out of it ,maybe Boost it.....
  2. poloboy4
    poloboy4 New Member
    washington
    i believe you can make it vtec get a y8 head (try to do 99-00) d16y8 head vtec ecu and harness and i might be missing some things but i know you do need that for sure.
  3. tabKola
    tabKola New Member
    Tewksbury MA
    You need head, Y8 OBD2B ECU because your car is a 2000, Y8 fuel injectors, a knock sensor, and Y8 5 speed IACV, intake manifold, and throttle body if your car is a 5 speed. You also need to perform the IACV 3 wire to 2 wire fix and add wires for VTEC. Again this is all asuming you have a 5 speed car.
  4. fastrxu
    fastrxu New Member
    ^^^ is completely right
    But it's called a mini-me swap look it up there's tons of write ups on it.
    Be very careful of where and what condition you buy your're parts though.
    I did this swap about a year ago without checking. And the head was warped, some valves were bad, plus new hg, new head studs, and small things the whole thing ended up being like $900. I cold have done an LS swap for that. (which I eventually did)
  5. Winarld_Woopafagoo
    Winarld_Woopafagoo New Member
    What about the exact same swap but on a 5 speed 96 ex? Would it be the same since its the same gen or what stuff would I need?
  6. E_SolSi
  7. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Isn't an EX already VTEC with a D16Y8? :hmm::huh:
