Can i use a 3 stage vtec on my D16y8 motor?
Discussion in 'Civic and del Sol - EG and EK' started by Manny 77, Jan 15, 2010.
  1. Manny 77
    Manny 77 New Member
    Can i use a 3 stage vtec selenoid on my D16Y8 motor??? can anyone post a P2J-003 ecu pic?? can i convert a P2J-J62 ecu from auto to manual?? Can i use the Y8 intake manifold?? Anyone done this before??
  2. BrutalB83
    Rochester Hills, MI
    Are you trying to give your D16Y8 three-stage VTEC by simply using an ECU and solenoid from a VTEC-E engine?
  3. Manny 77
    Manny 77 New Member
    If that possible or what???
  4. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
    -vtec is vtec. You cant really change it up, you can change the activation point to a diff RPM(buddy club vtec cntlr)
    -the solinoid does not change the vtec stage if thats what your asking. It only opens a port to allow oil psi to push the vtec pins to lock the 3rd cam lifter (only on intake portion for d16, B/H/K series change both intake and exhaust)
    -unless you get a cam shaft, and change the cam profile lift,duration,etc *just a simple explaination
  5. Manny 77
    Manny 77 New Member
    Well i dont know i guess you are not well informed of a 3rd stage vtec.... Is supposed to work with 12 valves from 2800 rpm til 5500 and at 5500 til red line 7300 work with full 16 valves... is a 2 selenoid vtec also known as vtec-e
  6. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    No, actually you are not informed. 3 stage vtec/ vtec-e is only available on the d15b
    and it works by leaving one intake valve is closed on all cylinders during 0-2500 rpm. From 2500 rpm up the motor works just like a regular vtec motor.
  7. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    Threads like this make me facepalm.
    VTEC is a fuel economy technology... I don't understand people's logic at all.
  8. eg'sforlife
    29 stumps, CA
  9. pooksy64
    HOUSTON tX
    :werd:
  10. newb
    newb phresh VIP
    Backwoods Northwest
    See sig below.
