can you put a 1999 b16 head on a 1993 b18a block
Discussion in 'HYBRID -> ED-EF / DA' started by time2rid3, Jun 19, 2008.
  1. time2rid3
    time2rid3 New Member
    ct
    sorry im new to this just want to make sure
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Do some research...
    It's called an LSVtec
  3. time2rid3
    ct
    yea i know that some people try to tell me that the block was not the same
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yes you can..get a vtec conversion kit,
    you will need the dowels,headgasket,and the oil line kit..
  5. time2rid3
    ct
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok,what all did it come with??and check your messages at the top right
  7. time2rid3
    ct
    oil line ,dowel, studs gasket i tap the head came tap allready
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    nice,,so put it together
  9. time2rid3
    ct
    it cant be that eazy
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    have you ever worked with honda motors?
  11. BrutalB83
    Rochester Hills, MI
    Why not? That's what you bought the conversion kit for, to make things easy...
  12. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    :withstupid:
  13. time2rid3
    ct
    yea but just swaps this is my fist ls vtec
  14. INJEN78
    INJEN78 HS LEGEND
    OHIO
    so do it up..if you run into problems just get back on and tell us where your stuck..i might be able to come help you depending where ur at
  15. time2rid3
    ct
    ya im going to rip off the old head tomorrow i still have to find that ecu
  16. BrokenRex
    BrokenRex New Member
    just so you understand, the dowels in the b18a are on the wrong side for a vtec head. you'll need to drill them out on the other side to make the head and block bolt together. i'm not assuming you didn't know this, but rather just making sure you understand why people even sell the kit.
  17. time2rid3
    ct
    ok so can i drill it or do i have to send the block to a shop
  18. BrokenRex
    you could drill it if you have a press, if not though, i wouldn't recommend it. if you get the holes even a little bit at any angle you'll have a hell of a time getting the head and gasket on.
  19. time2rid3
    ct
    ok im lost...lol do i have to drill on the block or the head
  20. INJEN78
    INJEN78 HS LEGEND
    OHIO
    im pretty sure you dont have to drill the block or whhatever,,thats what the conversion kit is for..
    last i though the b16 heads had 4 places for dowels.and theose 4 places are a little smaller than the ls which only has 2 places(a little bigger)
    so you take your dowels and put the bigger end down into the block..the thing is that you might need to open the holes on the gasket up a little bit to fit over the bottom of the dowel
