I just installed a jdm h22a into my 95 prelude. It runs but at idle after reving high flucuates between 750 and 1200rpm. The check engine light is on but it wont give me codes. I jumped the two wire connector under the console but the engine light did not blink, however the srs light started blinking non stop. Also now that i have jumped the connector the door ajar beep works even with the key out of the ignition! i tried disconnecting the battery to reset but it didnt work. Can someone please tell me what the hell is going on!?!? Thanks in avance.
