car wont start after getting gas
Discussion in 'General Tech and Maintenance' started by flydex28, Nov 27, 2008.
  1. flydex28
    flydex28 Senior Member
    Oregon coast
    Man I always have the strangest problems with my car. Now whenever I go put gas in my car...it doesnt want to start....well i take that back...it starts and runs for about1/2 a second then dies. Then it wont start again for a couple of minutes. I have to sit there trying over and over again to start it looking like a dumbass until it decides to start. I have all new plugs, wires, cap, rotor. I went online and noticed some other people having the same problems...mostly accords. Does this sound familiar to anyone. Oh and it only does it when i get gas. I can hear the fuel pump priming and I can run the car, shut it off and then start it again just fine...only when I get gas does it do this.:confused:
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    The times it doesn't start up, can you hear the fuel pump priming or does that not turn on?
  3. flydex28
    Oregon coast
    yeah...i can hear it every time.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    are you dead on e when you put gas in it when it does it
  5. SneakyTouchYourPlace
    SneakyTouchYourPlace New Member
    Don't top off the tank EVER EVER EVER EVER. When it clicks, its DONE. On a lot of cars, you will ruin all the evap stuff, starting with the carbon canister and vaccum components. End up running so rich that it won't run. They get flooded when you put more fuel to the car that the tank can't hold, it flows through the evap lines and fills up the canister. If you add fuel all the way to the top of the filler neck, it will find its way into everything in the evap system.
  6. MthaFuknGreen
    Lodi, CA
    i overfilled mine once on accident, it still said less than half a tank..
    what are the symptoms fuel getting into places its not suppose to be?
  7. SneakyTouchYourPlace
    Depends on the car and how it handles its purge, usually difficulty starting on some and random stalling on others. Usualy a purge or vapor managment valve will open to allow fuel vapors into the intake from the carbon canister. If it sucks in raw fuel instead of vapor, it will flood the engine. Some cars are designed to open during startup, some are designed to open during hot cruise.
  8. flydex28
    Oregon coast
    Well lately i've only been putting about half a tank in. And no its not on E...usually fairly low though.
