Check Engine Light
Discussion in 'General Tech and Maintenance' started by Viperlocc_B18C1, Apr 10, 2003.
  1. Viperlocc_B18C1
    Viperlocc_B18C1 Senior Member
    Madison, WI
    Well every once in a while, after the engine has been running for a while, ill shut it down for bout 5 to 10 min and start it up again and while driving, and after gettin on the throttle a bit, the check engine light comes on. anyone know what the deal? i know the knock sensor isnt hooked up and it should be but hey.
  2. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    pull the code, otherwise it's just blind speculation
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i'm going to bet that it's the knock sensor if it isn't hooked up.
  4. 92LudeSR
    92LudeSR Junior Member
    my ecu is putting out code 12 (EGR) and code 23 (knock sensor)...i don't even know where my knock sensor is located..any help in finding it/fixing the problem?
