Civic motors 92-95
Discussion in 'Engine Building' started by IMPORT PRO, Dec 28, 2002.
  1. IMPORT PRO
    IMPORT PRO Junior Member
    Which motor should I look for when buying a civic....
  2. chet
    chet Senior Member
    st petersburg, florida
    how much do you want to spend?
    how fast do you want to go?
  3. IMPORT PRO
    money out the picture, like when you go to a car lot, what year car and what motor should you look for !!! I'll build my own car from the motor
    that I need..
  4. Havok
    Havok Senior Member
    Florida
    92-95 Civic hatch or Del sol Si or better
  5. pissedoffsol
    fuck the sol
    buy a hatch
  6. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    92 Civic VX hatch - very light and already wired for VTEC!
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :werd:
  8. E_SolSi
    any 92 civic is already wired for VTEC
  9. chingro
    chingro Senior Member
    :werd:
  10. xj0hnx
    C.C.TX.
    Yes they are wired in the cars,but it doesn't continue to the engine harness except in the vx/si/ex.Actually wait a minute,I think they may go into the engine harness but are in the loom that is capped at the end on the passenger side.
  11. chingro
    u would still have some wiring to do..
  12. xj0hnx
    C.C.TX.
    o2 sensor and knock if your ecu looks for it.
  13. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    are you talking about what car has the best engine stock and you would be building off that engine without doing a swap? If so than a civic si a del sol VTEC
    <---- seen 95 del Sol vtecs (VTEC trim has the b16a3, a dohc vtec high reving engine) go for 7-10k with 100k miles on them, good luck finding one)
    other than the del Sol VTEC, no usdm honda really had a good engine in them untill later with the integras with the b18b (great for turbo) and the b18c (gsr and later typeR) you can not go that far with a factory USDM orginal engine in a honda. Swap is your only sollution (reliable solution) on the d16z6 you can go turbo but it costs just about the same as a swap and reliability is shot. Find a hatch with a blown engine or if possible, a 92 hb or a vx (light and wired for vtec) we say already wired for vtec is good because you can through allmost any obdI engine in there with little fabrication/wireing
  14. djextremity
    What I meant is that the VX is light and it's wired for VTEC. Not that the difference between the VX and other models is VTEC wiring, but that it's lighter and still wired for VTEC.
  15. projecthonda
    projecthonda Junior Member
    really my buddy i work with had a cx hatch and he threw a gsr in it but i think the wiring harness didnt come ready for vtech
  16. Jeef
    Jeef NO MA'AM Moderator VIP
    It's VTEC ASSHOLE.
  17. E_SolSi
  18. djextremity
    Easy, pal. You're a mod?
  19. b16ahatch
    b16ahatch Senior Member
    Try to find a civic cx hatch. Might be cheaper considering its a base model, no fancy stuff. same weight as the vx just not prewired for vtec
  20. xj0hnx
    C.C.TX.
    cx or vx both weight the same.
