Civic w/ itr swap distributor wires
Discussion in 'Civic and del Sol - EG and EK' started by unknownvtec, Jul 17, 2010.
  1. unknownvtec
    unknownvtec New Member
    im doing a swap and ran across a problem with the distributor wire.. im using a 97 civic ex wire harness and the distributor harness does not fit.. any idea if i should get it rewired or get a new distributor??
  2. egb19c
    egb19c New Member
    What distributor are you using??
  3. 99sidude
    Ohio
    Make sure you routed the main harness correctly. You may need to extend some of the wire harness branches. This is easy with a decent soldering iron, heat shrink tube, and quality electrical tape.
  4. mntlkase
    mntlkase Local neighborhood prick!
    New Orleans, La
    If u are using the jdm diizzy that came wit the motor it wont work. The plugs between usm and jdm are different. Get a usdm b16 or gsr dizzy, swap em out, and ur good to go.
  5. dateg513
    dateg513 New Member
    cincinnati
    if you can do a lil wiring just cut plugs dizzy wires are all same color's just different clips solder, heat shrik them
  6. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    My OBD1 JDM dizzy on my B16 plugged right into a USDM D16Z6 Engine Harness.
    What year is the ITR swap? Could be OBD2A vs OBD2B thing?
  7. 95EGCoupeVtec
    95EGCoupeVtec SOHC VTEC at its best
    South Mississippi
    yeah if your ITR swap is 98+ spec, its obd2b which the dizzy plugs are different. your car being a 97 means its obd2a.
  8. mntlkase
    New Orleans, La
    :D thank ya sir. lol
