CIVIC WONT START! please help
Discussion in 'Civic and del Sol - EG and EK' started by smoothekang, May 2, 2009.
  1. smoothekang
    smoothekang New Member
    I have a 96 honda civic dx that wont start, ive checked the grounds, got a dizzy, new wires, poured gas in intake, jumped battery, checkd compression which is all average of 115-120 psi (not sure if thats good or not), changed out injectors from a bseries into it to test to see if it even starts, timing is lined up, not sure what else now.....any info. would be appreciated thanks...
  2. delcivic
    delcivic New Member
    New Castle Colorado
    stock motor or swap? more info would be helpful. are you getting fuel to the fuel rail? are you getting spark though the plug wires? you replaced the dizzy but what about the cap and rotor? ive seen hairline cracks in rotors ground out in the dizzy and prevent any spark from reaching your plugs.
  3. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    115-120? seems a bit low in a d16y7. I'd mabey think head gasket but the car should still turn over.
  4. smoothekang
    stock motor, i did the screwdriver ground test and seen sparks for all 4 plugs, ive un screwed the fuel filter plug to see if the pump was giving fuel, it was GUSHing out, Ive even switched out spark plugs from a b series just to see if it runs, i even switched out ecus to see if that could b the problem, still wont start.
  5. smoothekang
    Injectors not spark plugs**, Im replace fuel filter and see how that goes..
  6. smoothekang
    just changed out fuel filter....still not starting..
  7. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    so let me make sure im reading this right, your getting spark and fuel but it will not start correct
  8. t4lude98
    t4lude98 New Member
  9. smoothekang
    correct, just changed out those components, just checkd the injector main relay next to glove box seems as if I unplug it the fuel pump stop of course... plugged it back in then it works, so I dont think dont think that relay is the prob.
  10. Pvtjoker122
    Pvtjoker122 New Member
    San Diego, CA
  11. smoothekang
    checkd all the ones that could possibly have an effect on it, from under the hood and dash
  12. delcivic
    delcivic New Member
    New Castle Colorado
    are you getting power to injector harness?
  13. smoothekang
    I imagine i would... so how do i check that?
  14. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    you have bad compression
    that could be your problem right there, i've heard of this..
    your motor new had 185 compression across the board..
    my y8 (same compression ratio) had 165, 155, 155,170 at 270,000mi, then i changed the head gasket and now she has 185,182,180,185. runs a whole lot better... CHANGE YOUR HEAD GASKET!!!
  15. delcivic
    delcivic New Member
    New Castle Colorado
    all four injector plugs should have a yel/blk wire that is 12v with the key on
  16. frodotoolbox
    frodotoolbox 92 civic si d15b
    sc
    i agree with josh. if your getting spark and fuel and still not running its your compression.
  17. Elnyne
    Elnyne New Member
    Sharpsville Indiana
    BS It's not compression! he has compression! albeit low, (check for sticking valves on that front) check your dizzy timing, and that your spark plug wires are on the correct plugs. outside that do your have a lit CEL? (check engine light) if so look up how to check and read the codes. it will tell you what is wrong.
    Jason
  18. smoothekang
    no check engine light, did all of the stated above
  19. Elnyne
    Elnyne New Member
    Sharpsville Indiana
    possible the dizzy is 180º out?
  20. Crx Kid22
    Crx Kid22 New Member
    boring, oregon
    ye check your valves, not much of a chance something is wrong but there is a chance
