clearance issues 98HF 14" Wheels front of EK coupe
Discussion in 'Civic and del Sol - EG and EK' started by d.b.cooper, Jun 17, 2013.
  1. d.b.cooper
    d.b.cooper Mid-life Crisis Swap
    Phoenix Metro Area
    I just traded my tired EG GSR swp for an EK(?) coupe...believe it is an EX model...went to put my wheels from the eg and they don't clear the calipers on the EX...
    help?
    I knew Will swapped in trailing arms from GSR to get rear discs on my EG....I always assumed the front disc was the stock civic set-up...
    Why they (or would they?) stock EX brakes have LESS clearance than the brakes (GSR?) on the EG?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Maybe it has Integra brake calipers on it? Not sure if they're different- but Teg guys shave their calipers down to run HX wheels.
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
  4. Matts96HB
    Matts96HB . Moderator VIP
    This is the type of stuff that makes an engineer cringe. :lol:
  5. d.b.cooper
    Phoenix Metro Area
    Thanks, Will! Talk about service after the sale...I think I bought your hatch like 7-8 years ago...I could remember your name but not your handle till I saw it in some old posts.
    You are presuming that any actual engineering went into the design of that bracket...More likely than not the guesstimated it then added a factor of 100%.. Cast steel is cheap, C.A.D. time expensive.
  6. civicious
    Houston, TX
    2005...8 years ago :-/
