cluster not working after LS swap
Discussion in 'HYBRID -> ED-EF / DA' started by frosty, Nov 27, 2007.
  1. frosty
    frosty Junior Member
    i just swapped a 93 LS motor into my rex and did an OBD1 conversion, it starts and runs fine. i have a couple problems though.. my tach, fuel gauge, and temp gauge aren't working, any suggestions?
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    check all your grounds again.
  3. frosty
    i regrounded the cluster, and all the grounds under the hood are in place/tight. where does the cluster get power from? all my fuses are good...
  4. frosty
    has no one had this problem before?
  5. 90b16ed
    90b16ed New Member
    You might want to check the connections in the rear of the cluster. Maybe you didn't connect them tightly...?
  6. sub95
    sub95 Junior Member
    Cali
    Yep i have to give mine a smack every now and then to get them to work. lol
  7. frosty
    the plugs to the back of the cluster are fine, as well as the plugs by the fuse box... could not having a sensor hooked up cause it? i only have one that isn't connected and its this:
    does anyone know what its for? the book for the rex says block thermosensor but the book for the integra doesn't have that sensor listed...
  8. sub95
    sub95 Junior Member
    Cali
    Looks to be for the Evap purge solenoid on fire wall or to vetc pressure switch..
    On my 90 crx on the back of the cluster left plug, left side second wire is key on+12 other then that idk.
  9. frosty
    i dont have vtec, its just an LS block... where does the cluster get power from, somewhere by the fuse box?
  10. wagovanb16man
    wagovanb16man i
    Tennessee
    Check the fuse under the dash? Mine did that right after my swap and had me stumped for a little while.. It's a shot..
    Do you have the OBD1 dizzy? That could make your tach not work.
  11. frosty
    i did an obd0 to obd1 conversion so i am using the obd1 distributor... which fuse powers the cluster, or which fuse did you replace? i thought there was only one fuse that went to the cluster and it was for the lights
  12. wagovanb16man
    wagovanb16man i
    Tennessee
    I don't know, just start looking through the fuses, it doesn't take long.
  13. frosty
    yeah i found the problem, i tried turning on my blinkers and they didnt work, turns out that fuse was blown... i feel lame but now everything works, thanks for the input guys
  14. wagovanb16man
    wagovanb16man i
    Tennessee
    No problem, the same thing had me stumped too.
