Hopefully you guys can help me out here, because I am completely clueless as to why it isn't working.
I have an LS/Vtec(obd1) in a 00 EL (obd2b)
I tried running an automatic P28 with a obd2b->obd1 conversion harness, and while the car would run fine there would be NO gauges working in the cluster. I thought this was due to it being an automatic ECU.
I now have a S300 equipped manual P28, and I can set it to stock P28, Stock P72 etc. but same thing, none of the gauges in the cluster work.
The cluster will only work when I have the stock ecu in.
I've tried 2 different conversion harnesses, one that was made by someone, and one from Streetrays.
I know the cluster works, since it runs fine when I have the stock ECU in. I only have problems when I try and run a different ecu with the proper conversion harness.
Do you guys have any idea what the problem could be?
thanks in advance
thanks in advance
