my 97 LS suffered catastrophic, everything fucked at once clutch failure.
The master was leaking inside the car
the slave was leaking
the clutch's springs broke out of the clutch and screwed up the flywheel and pressure plate.
But, I replaced the master and slave, then added a stage 1 exedy clutch and pressure plate, and had the flywheel machined. Its smooth like butter now, and stronger than stock!
Yeah, it eats a hole in your wallet!
