clutch question....
Discussion in 'HYBRID -> BA-BB /CA-CD' started by gunz2165, Jan 12, 2010.
  1. gunz2165
    gunz2165 Member
    connecticut
    i swapped an 93 h23 in my 93 accord. my dumb as forgot to change the clutch before i dropped the motor in. im running low on money at this time and have the clutch from the f22 that came out of my accord. i was told by a local honda dealer that the clutch will fit on my h23. my question is can anyone point me in the right direction or just flat out tell me how thick the stock clutch should be before i rip the tranny outta my car and put a clutch in that doesnt have much life left.:confused::confused:
  2. 99sidude
    Ohio
    Check a fsm, it should have a spec on how to determine clutch condition. I'd pick up an exedy stock replacement. Cheap and it will last you 100k+ depending on how you drive.
  3. JadeDM1tegi
    JadeDM1tegi New Member
    hey i have a problem my clutch pedal is all the way down and my gears dont go in but the car turns on. anyone knows wat it is????
  4. bluejcivic
    bluejcivic New Member
    if you shut your car off and your able to put your car in any gear, then its your clutch, or your master/slave cylinder
  5. JadeDM1tegi
    ok thanx..
    and if it doesnt go into gear?
  6. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    if the pedal is stuck down then your slave cylinder is out.
  7. bluejcivic
    if you press your clutch, and you cant get it into gear the problem is probably in your clutch master cylinder or slave cylinder.
  8. 94tuner
    94tuner New Member
    I also have a problem with my clutch when i engage it it makes a squeking noise and then it does it again when i release it all my gears work fine though. Any ideas?
  9. bluejcivic
    your release bearing is probably dry, it needs a little grease on the input shaft sleeve so it can slide easier.
  10. 94tuner
    94tuner New Member
  11. 94tuner
    94tuner New Member
    Im guessing the only way to do that is to remove the transmisson?
  12. caboose
    caboose USDM to the bone
    Hamilton, MI
    or its a Toyota
  13. 94tuner
    94tuner New Member
  14. 99sidude
    Ohio
    bazzzzzing:D
  15. caboose
    Hamilton, MI
    Yeah, you have to pull the trans off the car. I wouldn't mess with trying to grease it up. With the amount of effort that it takes to pull the tranny might as well be safe than sorry and just buy a new one.
  16. caboose
    Hamilton, MI
    Sorry reread your post. Sounds like it might be the throw out bearing linkage. I would pull the tranny and inspect everything and make sure that it moves nice. Clean and grease anything that squeaks or doesn't move easily. If your throwout bearing seems worn, I would replace it.
  17. 94tuner
    94tuner New Member
    Yeah i figured i would just replace it and upgrade my clutch while i got it out
