I've been looking at the act clutches and I need to know the difference between the 4 puck and 6 puck. Is one better than the other ? I'm looking for a performance cluch that is best for street driving and race, and not too much pedal pressure. I've been in some cars with performance clutches where the clutch pedal was so hard that you need both feet to press it in.
how much power are you making or planning on making? a 6 puck or organic type disk would be best for streetability. the big thing is to make sure you get a sprung clutch. an unsprung clutch will chatter a lot and be really rough on the street. also the pedal pressure is affected by the pressure plate, not the clutch.
