im a noobie to this and was wondering when other ppl say all those code like Code 15, Code 21, where will you be able to see these code on the car to see whats wrong.
thx for help
depends on which car you have - on some you can look at the ECU and see a red flashing light and you count the flashes - on others the check engine light will flash after you put a jumper in the connector under the dash
