Cold Air Intake???
Sofast
I just swapped a B18a1 into my 91 CRX. What do you all have for a cold air intake? Which year, make and model of intake did you get to fit this swap? I want to make sure when i order it fitment will be good. Thanks in advance
No to O O O Oreillys. I just ordered a 90-91 itegra intake to see if it will fit. Thanks
the da intake is what i was thinking might fit too. im sure it will be close enough, may have to cut it a little or something.
I think there is a difference in throttle body size. I am pretty sure the DA is larger so a 88-91 d16 pipe adapter wont fit. I will probably have to cut a little down from the DA pipe.
