Hey all, I'm parting out my Mini-Me swap and going to a full on B
I'm located in Ottawa IL, 61350, and my email is dasfinc@hotmail.com
I have a Fresh D16Y8 head, 3 angle valve job, mill, and pressure test it to make sure everything was clean and new.
The head has been on my D15B8 block for a few months, but the car has hardly been driven *I didn't torque my headstuds down enough and the headgasket let go right away*, I have the paperwork to show the head was redone, and its in great shape, it also comes with an AEM Tru-Time adj. Cam gear, Valve cover, Vtec Solenoid, Water neck, and OBD1 Dizzy!!!
WITH
a FULL D16Y8 intake manifold with a fuel rail, injectors, throttlebody, and adjustable FPR. I had this on the head mentioned above, this is a Manual intake manifold so its what you'd need to do a intake manifold swap on a D16A6 or Z6, and it comes with EVERYTHING listed above, FULL manifold!
$250 picked up or delivered with 40 miles of 61350!!! (I spent $250 on the valve work, mill, and pressure test alone, I will not take less as this is a full head with Vtec solenoid and valve cover and an adj. cam gear)
*Here is a picture of it before it was on my motor*
I'll even throw in a aftermarket Tri-Y Header!!!
This is EVERYTHING you need to slap this onto your block minus the studs (Or if you have a OBD2 car a different Dizzy)
I can be reached at Dasfinc@hotmail.com
WITH
