COOLING ishue in a B18C OR B16B into civic EK 96 ??
Discussion in 'HYBRID -> EG-EK / DC' started by loverboy, Jul 27, 2007.
  1. loverboy
    loverboy Junior Member
    Hey guys !
    Im going to do soon this swap in my EK 96 coupe.
    My question is my radiator will be good enough 4 the new engine ?
    I attached a picture of my radiator (i dont know if it 1 or 2 cores) ?
    If u think that i have to replace it what r my options ?
    Thanks!
  2. welfare
    welfare Ancient Member
    New York
    I wouldn'tbe sure what radiator you have in there right now, but you have alot of options for cooling.
    You could use a stock radiator for a 99-00 civic Si (b16a2) that way the water necks on the radiator would be the right size for your B swap, and it's 2 core.
    You could get an aftermarket radiator from any number of companies including Koyo, Fluidyne, Visteon and OBX
    There are also some no-name companies, but to me a radiator is a radiator and as long as it's all aluminum (no plastic end tanks) it'll last quite a while.
  3. loverboy
    Thanks !
    But we havent got the 99-00 Si model in our country nor any integra model.
    Is there another model of honda that i can take his radiator and plant him without modifications?
  4. welfare
    New York
    Ebay would be the best bet for you, most companies will ship worldwide
  5. loverboy
    Isnt there other honda models that i can take the double core radiator from there and transplant it ?
  6. 93chaosdx
    93chaosdx 93dxowner
    you could use a delsol that is a vtec. i bought a twin core delsol radiator. you can also use this product called water wetter. it is a liquid to add to your antifreeze that is guarenteed to run 20 degrees cooler.
  7. eg6sir
    look up radiator doctor on ebay.. you can get a new dual core koyo for $90 shipped
  8. loverboy
    i saw there some GSR long rad' what is the difference between the Si rad and the GSR rad'?
  9. loverboy
    Ok Guys so these are my options what do you say:
    1.mishimoto rad (46mm core depth)- $150+$65 delivery
    Link: 92-00 Civic Radiator / Universal
    2. mishimoto rad + 1300CFM fan neukin brackets (46mm core depth) - $230+$95 delivery
    Link: 92-00 Civic Radiator and Fan/ Universal
    3. visteon rad' + spal fan (1"=25.4mm core depth) - $259+$60
    Link: eBay Motors: Visteon C&R Alumimum Radiator 92-00 Civic with Spal Fan (item 270152728180 end time Aug-14-07 08:28:01 PDT)
    4. KOYO rad' (2.09"=53mm) - $280+$105
    Link: eBay Motors: KOYO RACING ALUMINUM RADIATOR D13B/D15BD16A 92-00 CIVIC (item 130139954191 end time Aug-08-07 23:58:35 PDT)
    What would u choose ?
  10. eg6sir
  11. welfare
    New York
    My feelings toward the smaller water necks is widely known, a better option would be eBay Motors: CIVIC DEL SOL 92-00 ALUMINUM RADIATOR B16 B18 B Series (item 250150905976 end time Aug-10-07 15:30:00 PDT)
    it is actually a little bit cheaper and from a company that i have bought from, but it has the right size water necks for the b series so that you don't have to crank down the clamps etc. etc.
  12. loverboy
    eg6sir, I peffer to pay an extra $50 and to get the whole aluminium radiator from a good company.
    welfare, what is size is the smaller neck and the bigger ones ? in the rad' link u posted the neck sizes r 1.25", is yhis the bigger diameter necks? if it is i know the mishimoto is the same diam', and i am checking about the visteon and koyo size.
    Now i troughly preffer to spend a little more money for buying from a familiar and warrantied compnay!
    U dont think my options r good ?
  13. welfare
    New York
    water neck sizs are
    1 1/8" for d series (30mm)
    1 1/4" for b series (1.25" or 32mm)
  14. welfare
    New York
    Oh, and the radiator that eg6 showed you is a great radiator,
    Koyo is one of the worlds leading manufacturer of aftermarket and OEM radiators, they are not a no-name company, and they usually have a 1 year warranty or more with their radiators.
