Alright..This will be one of my last threads about the zc...well prolly not but i'll try to keep them mostly to this thread from now on.
I have just a couple of questions..
I've taken my zc apart and already had the head resurfaced...they took off 0.008s off of it, but there is still a mark/dip in the block that is about the size of like half a penny between 2 of the holes...it doesn't make contact with any of the holes...so basicly it is just in the flat peice of the block. I layed the blown head gasket up to it and it was in one of the worse spots of the head gasket. I'll try to take some pictures tomorrow and post them online so yall can see it a bit better...but is this going to affect my engine in any major way...I'm planning on adding a n2o kit soon...prolly wet after asking a few people..they dont seem to liek dry that much. If i can get a good deal on a turbo kit i'd be adding that also too..
And is taking 0.008's off going to raise my compression much?...
I had my block set to the side and someone moved the pistons on me...now what does this mean as far as setting it up w/ my cams and or timing...How do I find the TDC again?
oh yeah...I pulled on of the head bolts out and there was a rather large amount of oil on it...It was basicly covered in oil... Should I be worried about this or is the oil on the bolt probably from the head gasket being blown? Or does this mean a cracked block?
I'll try ot post pics of the head + old head gasket tomorrow.
Thanks
Nathan
Thanks
Nathan
