Crank swap
PortLuver
Need a crank for an h23. Will a crank from a f22 work in a h23 block?
bump
I guess when it comes to tech ? instead of your regular will a z56 fit into an xyz no one has a comment. sorry to of such a bother.
Would i have to use the the connecting rods from the F22 as well.
I'm not sure about that. You can google that and you should find links to other forums that can help you.
