crx door help ?
Discussion in 'Civic and CRX - EF' started by AHHVTEC, Aug 27, 2009.
  1. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    was wondering will 91 crx doors fit on a 88, i mean are they the same door other than the panels
  2. AHHVTEC
    Alabama
    im thinking the door moldings wont line up
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    91 has the seat belt mechanism in the doors and the 88 doesn't
  4. AHHVTEC
    Alabama
    ahh thats right i knew i was forgetting something, thanks man
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    the 88-89 si actually have the door mounted belts as well..
  6. eg6sir
    :werd: my 89 si had the mounted seatbelt thing on the door
  7. AHHVTEC
    Alabama
    well the 88 does not, im also thinking the molding on the 90-91 is higher up
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i rlly dont think it is...but its a possibility
  9. jlicrx
    Colorado Springs
    Honda part numbers for the door skins are the same on all of them - i think that just the molding itself is different
  10. caboose
    caboose USDM to the bone
    Hamilton, MI
    The window of the door mounted seatbelt is about 1" narrower than the window of the piller mounted doors. This is because the back of the door frame is wider to fit in more support for the seatbelt mechanism.
  11. blasterman87
    blasterman87 New Member
    the canada built hondas had the seatbelts on the pillar, the one built for american specs have them on the door. i believe this is true for all 88-91 models, my 89 has them on the pillar and was built to canada specs. it has the sticker on the radiator support
  12. LOWLIFE
    LOWLIFE Local Diesel Fanatic
    Fort Worthless
    a buddy of mine has a USA spec 89 HF and the seat belt is pillar mounted.
  13. blasterman87
    hmm..idk then thats what i was told i guess i was wrong
  14. eg6sir
    SI's had the door mounted seatbelts
  15. blasterman87
    dont think so, my 89si (hatch, if it makes a diffrence) has them on the pillar, and my 88 hf crx had them mounted on the pillar also.. idk
  16. AHHVTEC
    Alabama
    all i know for sure is that a 88 hf has them on the pillar, because im looking at it lol
  17. blasterman87
    so did you ever find out what doors will fit? i thaught in 90 they made the crx a little longer, but i dont know what they stretched. the doors or just the body
  18. AHHVTEC
    Alabama
    well from what i can tell the doors are almost the same other than seatbelt, door impact bars and the molding is a little different, but for years i have thought the doors on the 90-91 was a little shorter from bottom to top, but i cant find info on that, but im confused because i didnt think that for years for no reason. i dont think anyhow lol.
  19. phyregod
    phyregod !!YTINASNI
    Central Texas
    The 88 Si had pillar mounted belts. If I were you, I'd just wait it out and get the correct door.
  20. AHHVTEC
    Alabama
    yeah thats what im gonna do, im thinking of just reparing the ones i got i was just hating to put that much bondo on it.
