crx injectors wont spary
Discussion in 'HYBRID -> ED-EF / DA' started by efnastytime, Jan 24, 2007.
  1. efnastytime
    efnastytime New Member
    nc
    i go ta crx si i just put a b16a in it the fuel rail is gettign gas but the injectors wont spary at all i took the rail off and turned the key and fuel pump comes on and fpr gauage reads 44psi but the injectors dont spary can anyone help me out
  2. fixed4 life
    fixed4 life New Member
    Haltom City TX
    Where they working before with no probs? What kind of injectors are you using with the swap?
  3. 801CRX
    801CRX Got Rice?
    UTAH
    Check to see if you have power to the injectors with a testlight.
    And check all your wires to see if there hooked up or crossed.
    I guarentee your not getting power to the injectors
  4. 801CRX
    801CRX Got Rice?
    UTAH
    It wouldnt matter if it worked before or not, because when you swap you change that out.
  5. efnastytime
    nc
    yes they were working b4 and i havent checked if there getting power do i take the clips of to do that or wat??
  6. Andrew
    Andrew Well-Known Member
    Tallahassee, FL
    When you say you "turned the key", did you turn it all the way to attempt to start it?
    If you just turn the key to 'ACC' it will not spray the injectors.
    The fuel pump, however, will prime the system and pull it up to full pressure when you hit the 'ACC' mark, but injectors won't do anything.
  7. efnastytime
    nc
    yes i tryed to satRT IT NOTHIN happens
  8. efnastytime
    nc
    ok my crx has the obd0 to obd1 ecu jumper harness wat do i need to do b/c i got obd0 injectors could this be the problem and also i got a resistor box any help from anyone???
  9. efnastytime
    nc
    ok injecors are not gettign no power but the ristor box has one plug that has power how can i fix this??
  10. klyph
    klyph Dismember VIP
    North Pole, AK
    Are you saying one side of the resistor box has power and the output to the injectors doesn't? Get a new box.
  11. efnastytime
    nc
    no the box is good but the injectors arent gettign power how do i get power to them
  12. Andrew
    Tallahassee, FL
    Hmm...
    Have you done anything to the harness? Any wiring, extending, etc?
    It's the stock harness right?
