crx needs engine
Discussion in 'Civic and CRX - EF' started by josh29, Aug 10, 2008.
  1. josh29
    josh29 New Member
    I need to know what engines will fit in my 1986 honda crx.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    how much money you got
  3. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    :ditto: A budget would greatly help us help you.
  4. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    K24.
    B20/VTEC
    B18C5
    B16B
    B16A
    meh.
  5. prpprimo
    prpprimo Hondaholic
    ABQ
    briggs & stratton ;)
  6. 91integrab16a
    91integrab16a New Member
    :werd:
  7. Slow&Delirious
    Slow&Delirious isn't fast or furious
    Boonville NC
    LS7, (cutting, torching, & custom farbication required) lol
  8. 89' Project Civic
    89' Project Civic d16a6/d16y8 "mini-me"
    St. Catharines, Ontario, Canada
    I have a d16a6 block out of a 91' Si, will that fit? you can put a V-TEC d16y8 head on it!.
  9. TravisCadello
    TravisCadello Banned
    Houston,Texas
    Yea, it will work but, Your gonna probbly be stuck where im at right now if your crx isn't Si, you'll have to do a dpfi to mpfi unless you know more about this than me then you'll be stuck for a while.
  10. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    He has a 86; it's not drop in, The D16A1 would probably the best easy swap for your car. The 88-00 D-series require more work(mounts, axles, linkage, wiring).
  11. efhondakid
    Akron-Canton, Ohio
    Hasport has the mounts to get a B-series in it, wiring would be the hardest part, and if it started life carbureted, for get about swapping it, as you have to change all the carbed fuel lines, gas tank, for the fuel injection parts, and do some major major electrical work.
  12. caboose
    caboose USDM to the bone
    Hamilton, MI
    I was going to say twin turbo ls7
    ... or did he mean which engine would fit easily? :p
  13. 91integrab16a
    just drop a 2jz in it and call it a day :)
