crx project w/b16 needs assembly
juggalojmv
i have a 1987 crx si project car with a freshly rebuilt b16a jdm motor. located in St. cloud, minnesota price is best offer
Car specs
rust spots on rocker panels and rear fenders has a subwoofer box behind the seats that covers the whole rear of the car kenwood cd deck,custom rear compoenent sets made with 8 inch rockford fosgate subwoofers and noname tweeters run on boston acoustic crossovers powered by a rockford fosgate amp, only has two out of the four subwoofers and no amp but wiring has been ran for everything, has a sunroof, short throw shifter uninstalled,coilovers uninstalled, body is in half primer but a bad job.integra radiator partially installed still have old engine and tranny setup must be took with the car but is damaged
Engine specs
B16a block and head
fresh rebuild on rings,rod bearings,gaskets
just under 70,000 on engine, 3000 on headwork
cometic head gasket
match port and polished
oversized valves
titanium retainers
skunk 2 pro series intake manifold
oversized throttle body
aem fuel rail
aftermarket fuel pressure regulator
mount swap for 88-91 civics/crxs
integra ls high geared tranny havent used it but when i bought it was told nothing wrong with it
aftermarket header
wiring harness partially installed
brand new aftermarket clutch
you can email me at juggalojmv@yahoo.com or call me on my cell phone at 320-333-4367 my name is tony
short throw shifter and coilovers not included with a trade for a hatchback shell but the old engine and tranny setup is
