1989crxsiB16A
i have a crx si with a b16a swap when i push on the gas peddle it dogs down then it revs fine as long as you keep it above 2,000rpms..it is not throwing any codes.. i rechecked the timing just in case & its dead on...i changed the injectors & fuel rail for the hell of it.....even changed the fuel pressure regulator...i think i have teh vacum lines right... any one have any suggestions..
thanks..
thanks..
