Crx/type R
Discussion in 'HYBRID -> ED-EF / DA' started by RRRex, May 25, 2003.
  1. RRRex
    RRRex Junior Member
    Been having some issues with my motor lately. 98 B18C5. Blowing white smoke. Plugs are reading lean and getting a humming sound coming out of the air intake filter from the throttle body. Anyone ever hear that before?
  2. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    well the smoke question, i should know but for some reason i forgot what white smoke means.. anyway, check your hoses around IM/intake. also, many aftermarket intakes to make a slight hum, b/c of the increase in airflow into the IM, it also might make a whistle when u turn the car off, this is also normal. sounds kinda cool too ( my car does it :D )
  3. SleEPeR_CRX
    another thought just came to me. whats ur timing at?, if ur running lean, then u might have the timing fully retarded. check that out and that might be the cause of ur lean problem. or check ur injectors.
  4. D See 2
    D See 2 Senior Member
    Baltimore, MD
    white smoke is usually coolant being burned. if it is blu-ish white then its oil being burned. and if its black smoke ur running rich as fuck. have you been running it hard,? if so more than likely a head gasket problem.
  5. RRRex
    RRRex Junior Member
    Yeah, the car is mainly a track car and gets beat on frequently. In fact, it only gets beat on. The timing was really advanced, I just pulled it back a bit after the plugs read lean. Been having an IAC valve issue which I think I sorted out. Also throwing a 71 and 72 code. Engine misfiring in cylinder 1&2. I know I have to take it in, but want to hear as many theories as possible so I don't pay for work I don't need.
