what u all think , is the compression going 2 b 2 high for 90 octane . Thats the highest octane we have in JAMAICA :roll:
Yup! You will know if you need a booster by listening to you engine. If it is knocking then you need to up the octane. 90 might be good for everyday driving, but I would still use the booster.
im pretty sure you dont want to do that if its your daily driver. find a compression calculator online and it will tell you the ratio. could be fine but i think it will be a little high.
i'd be nerveous as it is on the stock ITR pistons. your running 11:1 compression on 90 octane....in jamacia heat. its a scary, scary thought. i wouldn't do it
