ctr pistons on stock ls rods?
Discussion in 'Engine Building' started by jiujitsuwhat, Feb 27, 2010.
  1. jiujitsuwhat
    jiujitsuwhat New Member
    hey guys, i ran through a puddle in the ol del sol... brock a rod in half and broke a piston skirt in cyl 1. while the bottom end is torn out would it be possible to swap in some stock honda pistons to raise compression while not giving me clearance issues? its a b18b1... what r my options guys? thanks in advance!
  2. jiujitsuwhat
    are the ctr or itr pistons for an 81mm bore?
  3. Briansol
    they don't fit ls rods.
    p30 b16 pistons do though and are probably as high as you want to go without doing serious cams/headwork to match.
  4. Magana559
    Magana559 The Warden
    fresno Ca
    PCT pistons will fit, just ahve to take off 1mm off on each side of the small end of the rod or the inside of the piston. Most machine shops will do it.
  5. jiujitsuwhat
    so on a stock b18b1 would p30 pistons and a set of 402s work without head work?
  6. Magana559
    fresno Ca
    yes it will work with no head work.
  7. jiujitsuwhat
    thanks alot bro! what wrist pins would i have to use? and any idea of what comp ratio that would bump me to?
  8. Magana559
    fresno Ca
    you would have to use stock wrist pins, it should come with the pistons. you would be be at a 11:1 CR.
  9. Briansol
  10. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Years ago, I saw a LS swap JG complete head in a 92-95 hatch with stock ECU, trans and bottom end gutted with little slicks (and H/I/E) hitting low low 13's the entire day (in 95 degree summer temps)
    It sounded crazy and distinct (in comparison to al the other hondas running) I would here it from a far and run to see what time he was hitting. Eventually found him in the pit and asked him about the set up.
    It can be respectful for sure and make some VTEC guys mad....and with P30 pistons, chip, tune......watch out.
  11. Magana559
    fresno Ca
  12. HA Motorsports
    HA Motorsports New Member
    I have used the p30 pistons in LS motors for MANY customers with great results. Compression is still very manageable with pump gas and it really 'wakes up' the LS engines :)
    I would NOT use the PCT pistons. This is way to much compression for a street engine, especially with any non-VTEC cams. You would need significant overlap to make use of that kind of compression - and on an LS that means crappy driveability
