ctr pistons
Discussion in 'Engine Building' started by t3t4si, May 14, 2004.
  1. t3t4si
    t3t4si Member
    I was just curious if the civic type r pistons fit right in my b16a2 motor in my civic si.
  2. brian11to1
    brian11to1 Senior Member
    Yes they will. you will have pretty high CR.
  3. katman
    katman Member
    PASADENA, CALIFORNIA
    Yes, they will fit but not directly.
    You need to have the rods modified at the wrist pin area in order for the CTR piston to fit on the B16 rods. About 1-2mm needs to be shaved off either side of the rod in order for the CTR piston to fit on the rod.
    If you take the pistons & rods to a machine shop and show them, they'll know what to do.
    Your compression will be in the 10.8-11.0'ish range...not bad at all if you stick to 91+ octane gas.
