CV shaft help
alright so i have an eg with a b20block and a gsr tranny, well monday night i snapped the bearings and all, on the driverside axle, and i went to get under my car to replace it, and the cv shaft looks different then the shaft on my old 89 civic, on this shaft halfway there is a bearing looking thing and a bracket that is bolted to the blockCan I pull the shaft out at halfway? or will i have to undo the bracket and pull the entire shaft out?please help
well if it does seperate halfway at the "halfshaft", does anyone have advice to seperating it, cuz ive tryed prying it apart and it just wouldnt come out-HELP
yes it has a half shaft/mid shaft on one side bolted to the block - guessing you already have pub pulled out to the side to give yourself room - grab hold of the metal shaft and push/pull back and forth - it will seperate - or take it to a shop if you can't get it
