D15 EG tranny to a D15 EF
Discussion in 'Civic and CRX - EF' started by drft204, May 31, 2008.
  1. drft204
    drft204 New Member
    hey i have an 88 dx but trannys f'd up and wondering if the eg's d15 tranny would bolt on right onto my motor and mounts.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes it will but you will need to use the flywheel and clutch also from the eg , and the ef tranny is a cable tranny and the eg tranny is hydro so you will have to convert your car to a hydro clucth or buy a kit from hasport to get around it.
  3. drft204
    drft204 New Member
    oh thats cool. so the tranny would mount perfectly on the mounts in the engine bay? and is there a way i can convert my car to a hydro clutch?
  4. AHHVTEC
    Alabama
    yes it will mount, but you will have to get all the pluming clutch master cylinder and all to do that. if i was u i would just look for a 88-91 si tranny, it will save you some money in the long run
  5. drft204
    drft204 New Member
    one junkyard here where i am is selling a dx tranny for 150 and an si for 200. but this other junkyard is selling there trannys at a flat rate of 75 dollars but they only have an EG and integra LX. and i don't even have a budget right now
  6. AHHVTEC
    Alabama
    id look around on ebay and stuff for a good 88-91 si tranny
  7. drft204
    drft204 New Member
    hey this might be off topic but does a b16a motor have the same mounts for my ef? cuz i'm jus trying to bring the car back alive before i do anything performance wise cuz i wanna see if the cars still worthy enough for an engine swap.
  8. AHHVTEC
    Alabama
    no there way different
  9. drft204
    drft204 New Member
    so only a zc engine will replace my d15?
  10. AHHVTEC
    Alabama
    you can put any honda motor in your car but you will have to buy new motor mounts and linkage and that kind of stuff
  11. BrutalB83
    Rochester Hills, MI
    Any D-series engine will swap in with stock mounts and bolt to your transmission. Anything else (B-series, K-series, F/H-series) will require different mounts and a different transmission...
