d15b / d16z6
Discussion in 'Civic and del Sol - EG and EK' started by bigballsmagerki, Jan 26, 2007.
  1. bigballsmagerki
    bigballsmagerki 95 ex
    So I have the stock z6 in my eg civic. From everything i've read and heard about i decided to purchase another z6 and build it out with eagle rods, sleeved, pnp, everything. Thats as far as i got with that plan. I've been looking around for another z6 for a decent price, low miles, (would It even matter about miles? could I got to the junkyard?) but online and can't seem to find other z6's. Is a d15b a jdm version of the z6? I can find plenty of them but are they the same thing? A little suggestions?
    Thanks,
    Nick
  2. 801CRX
    801CRX Got Rice?
    UTAH
    No, the d15b is .............well
    A d15 block with pretty much a z6 head on it.
    And the d15b cam is more aggresive than the z6's
  3. bistec
    bistec Project EH23
    I you're going to buid it , miles shouldn't matter. The d15b is different from the z6 and is not a jdm version of the z6. Less displacemnent, different internals, as 801crx said camshaft more agressive ( and looks like they can't be interchanged - someone corect me if wrong), no purge solenoid on d15b, the d15b block is pretty much a d15z1 block. They share the same timing belt , water pump . You should try d16z6 vs d15b on the search engine.
  4. bigballsmagerki
    know where I can pick up a z6 from anyone?
  5. bistec
    bistec Project EH23
    I have one . Just pulled from my sol si. Interested? Pm me.
  6. Black Ty 1.5
    Black Ty 1.5 New Member
    Brampton,Ontario
    Hey bistec watever happen to ur project last time i saw u was have problems wit starting up or somtn
  7. bistec
    bistec Project EH23
    It's running without any problem:) . I love that engine. The problem was a bad ground connection. Thanks for asking. I'll be posting pic today. May be vids if possible.
  8. Black Ty 1.5
    Brampton,Ontario
    Great man cant wait to see da full swap story
  9. juicedz
    juicedz Member
    edgewood, md
    D15B
    VTEC
    Found in:
    1991-1999 Honda Civic VTi EG4
    Displacement : 1493 cm3
    Bore and Stroke : 75 mm X 84.5 mm
    Compression : 9.6:1
    Power : 130 hp @ 6800 rpm & 102 ft·lbf @ 5200 rpm
    Valvetrain : SOHC VTEC
    Fuel Control : OBD-1 MPFI
    3-stage VTEC
    Found in:
    Compression : 9.6:1
    Fuel Control : OBD-2 MPFI
    D16Z6
    VTEC
    Found in:
    1992-1995 Honda Civic EX/Si, Del Sol Si,
    Displacement : 1590 cm3
    Bore and Stroke : 75 mm X 90 mm
    Compression : 9.4:1
    Power : 125 hp @ 6600 rpm & 106 ft·lbf @ 5200 rpm
    VTEC Switchover 4800 rpm
