I am currently in process of this swap.
I'm converting to OBD-1 so I have to change the distributor (and repin the plugs), use OBD-1 injectors (requires simple rewiring/soldering), extending wires for map sensor (92-95's is on TB, 88-91's is in the black control box), and making/buying jumper harness for the ECU.
In addition, you must use the 88-91 driverside motor mount (must cut some of the 92-95's timing belt covers to fit)
To use the vtec you'll need to add two wires (vtec sig, and vtec oil press)
If you buy replacement parts for the motor, get 92-95 parts.... but keep your ef clutch/flywheel/alternator,a/c,p/s (the waterpump, tensioner, timing belt from the ef won't work)
I'm almost done with my swap... should be finished around this Wednesday.
BTW, if you are a DX (dual point) I suggest converting to MPFI first... deal with any issues you may have, then do the swap. If you do it all at once, you may get lost in the troubleshooting.
