D15B7 head on a D15B2 will it work?
tepco
New here
Hello I'm new here and own a newly aquired 1989 Civic HB. It is in need of some TLC, I'm looking for a head because the cam is seized. Other then that the car is in good shape.
Looking forward to getting this car on the road, my goal is Fuel Economy not power so it should be interesting.
Tim
The d15b7 head is OBD-1 while your block is OBD0 and I don't know how that'd work out. But if you do the research and come up with something, check my sig.
Thanks the part numbers are the same for the head but the cam # is different. Im not sure if this will matter or not.
Can anyone help?
Thats probally cause it has different cams....if anything itll be better
Run the B7 head with the B2 intake manifold and all the B2 electronics and sensors and it's basically a plug and play install.
