d16 block w/ d15 head
Discussion in 'HYBRID -> EG-EK / DC' started by atx96EK, Oct 7, 2010.
  1. atx96EK
    atx96EK New Member
    would a jdm d15b vtec head work with my d16 block? i've been looking for info on this mini me swap, but so far i haven't found as much detail as i want.
    thanks!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes it will work, it will work just like the z6 head
  3. atx96EK
    atx96EK New Member
    awesome. what about ecu? the head comes with a p2p and the obd1 to obd2 harness. or should i just buy a p28?
  4. AHHVTEC
    Alabama
    is it a obd1 head ? if so just use the p28 or p08 but i would just go p28
  5. atx96EK
    atx96EK New Member
    i'm not sure. i'll have to find out tomorrow. i'm guessing obd1 though.
  6. atx96EK
    atx96EK New Member
    is the mini me worth it? i'm not trying to get crazy hp gains but i'm gonna end up buying a new timing belt and dizzy and i'm having issues with this motor so i figured i'll just do the swap.
  7. AHHVTEC
    Alabama
    its hard to say i mean if your not gona have much money in it then why not but if your gona be dropping a bit then no, not worth it. i mean you can make a sohc fast but it takes a lot of money.
  8. atx96EK
    atx96EK New Member
    not looking to drop a ton of cash in to it. i figured i'd spend as much fixing it as doing a swap so might as well upgrade. i'm getting the ex tranny too so it should make a nice difference.
  9. AHHVTEC
    Alabama
    yeah, if the head is needing to be replaced might as well upgrade
  10. Project Rex
    Project Rex New Member
    help
    will a d15b2 head work on a d16a6 block i need to know because i need to get my rex on the road and what will i need to do to make it work plz help
  11. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    You should start your own thread but yes, d15b2 head casting is the same as d16a6. Just swap the cam, distributor, and intake manifold.
  12. atx96EK
    atx96EK New Member
    what are the differences with this swap and a y8 swap? are there any big differences or can i follow the y8 write up on jdm universe?
  13. josh miller
    josh miller New Member
    hey ahhvtec send me a messege please im putting a d15 head from a vx into a d16z6 and i have some questions please messege me when you read this
  14. AHHVTEC
    Alabama
    your gona need to get 15 post before we can pm each other
