D16 Vs. anything else.
Discussion in 'Engine Building' started by Honda20000, Dec 8, 2008.
  1. Honda20000
    Honda20000 New Member
    I've got a 2000 civic DX hatchback Special edition with the stock D16 in it. I bought this new 9 years ago as a commuter and want to start a build up on it. My question is, is it worth it to modify the D16 in it? Or should I build up another engine like a B16c or h22a? Money would not be a factor as I have a 2008 civic coupe and this would be a ground up build.
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    If you are open to a reasonable budget with a modest amount of work, I would say B16 swap. If you want to spend a little more and do lots of fabrication and have a bunch of work on your plate, I'd do a K swap. Ultimately, it depends on what you want to spend, how much time you want to do it in, and what you will use the car for.
  3. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Definitely depends on your goals. There's quite a few D's that are putting down more power than stock B16s at less the total cost; but the B16 has more potential.
  4. efhondakid
    Akron-Canton, Ohio
    What he said.
  5. 95b16coupe
    95b16coupe New Member
    ct
    it really depends on your power goals and what kind of driving you are going to do with it. if you want 200hp, i would say just turbo the D. if you want upwards of 400hp on a full build, i would suggest an ls or gsr swap.
    if you have unlimited funds (read: $10k+) i would build a k-series.
  6. Honda20000
    What were the K series in?
  7. 95b16coupe
    ct
  8. 95b16coupe
    ct
    when i hear that, my first suggestion is to buy something other than a honda. don't get me wrong, I love hondas. But if I had unlimited funds, there are hundreds of cars i would rather have. and most require little to no modification on my part.
  9. JAYDEE-M
    JAYDEE-M New Member
    please dont go with the d series, weather its single cam or not, their really not worth building for the little performance that ull get outa it especially for not having a rex or older hatch.....personally go with another motor, if ur in a money chrises go with a b20 or h22
  10. JAYDEE-M
    JAYDEE-M New Member
    and d@mn if money isnt a factor k20 man
  11. 95b16coupe
    ct
    yeah, you should definitely get a dual cam d-series if you can.
  12. Honda20000
    Well when i say money is unlimited I don't mean millions or hundreds of thousands, I mean I have money do build it the way I want. It won't be a quick engine build and drive away type of deal. I want something I can build from scratch, something to take pride in and spent time doing it. Anyone can spend $40,000 (theirs or the banks) on a car they want. I want to spend it on a car that I can build myself. Sarcasm is the easiest responce to any question and can be found anywhere. I would just like to learn more about honda tuning.
    I have a stock D16Y7. I'm not looking to win any races but 200 HP is good enough to hold its own. Is there anyway to make this a VTEC engine or what can I do to this engine to achieve roughly 200HP?
  13. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  14. 95b16coupe
    ct
    do you want to be all motor or do you want a turbo?
  15. 95b16coupe
    ct
    are you referring to my post?
  16. Civicdx88
    Civicdx88 New Member
    d15b7 block wuth d16z6 head
    I have a quick question, I've recently been doin some research on mini me swaps b/c im interested in doin one my self. I have a d15 b7 block with b7 head but i could get a d16z6 head from my cousin so i was wondering what would be the best build for boost? I was hoping of hittin 200 whp or more if thats possible soooo what would be the best setup?
  17. 95b16coupe
    ct
    start a new thread.
  18. Honda20000
    How reliable is a D16 with a turbo? Would it be more reliable to have an H22A n/a?
  19. 95b16coupe
    ct
    if it's tuned, it will be just as reliable as an n/a with mods.
    any car that is not 100% factory, will not have factory reliability. it's just how it is.
  20. eg6sir
    d16a1?
